Pay monthly - EE
  • EE
  • Orange
  • T-Mobile
Please note, charges for 1) roaming in Europe and 2) certain service numbers may no longer be up to date in price guides listed below. From 15th June 2017 EU roaming usage will be deducted from your UK allowances. For any out of bundle calls you will be charged the same or less than the standard UK rate for that usage type. Please see either roaming charges or charges for calling non-geographic numbers
Please note: Our terms and conditions come in a PDF format
Pay monthly plans
Moving to EE if you have a 4G phone
Moving to a higher price plan
Available to existing EE customers by invitation only.
Customers must have been with EE for at least three months. If you choose to move to a higher price plan, once we confirm the move, from your next bill date you will pay the higher monthly plan charge for the rest of your minimum term and your data allowance will increase. Your minimum term will not change and the end date will remain the same as on your existing plan.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
