BT Sport: Register & set up
  • EE
  • Orange
  • T-Mobile
Here, you can find out how to register and set up BT Sport on your mobile device.
How to get the BT Sport app
The easiest way to get the BT Sport app is to:
Text SPORT to 150
Or, if you’re a pay monthly connected tablet customer, call 07953 966502.
You can also get the BT Sport app:
  • when you join EE or upgrade in an EE store or through customer services
  • by calling 150 from your mobile
Setting up the BT Sport app
You'll need a BT ID username and password to log into the BT Sport app. The info below explains how to do this.
How long does it take to activate my BT Sport account?
When we send text messages and emails, they usually arrive pretty much straight away. But you should allow up to 24 hours for them to arrive.
Once you’ve downloaded the BT Sport app to your phone or tablet, open the app and login with your BT ID username and password. Then you’re ready to start enjoying the app.
The BT Sport app is available on the following devices:
iOS
ANDROID
WINDOWS
iOS 8 or later
Android 4.3 or later
Windows 10 or later
Download it here
Download it here
Download it here
You can usually check the operating system in the Settings menu of your device.
Apple users can update their operating system by going to Settings > General > Software Update.
On Android devices, follow these steps:
  1. Open your device's Settings.
  2. Tap About Phone or About Device.
  3. Tap Android Version to display your version information.
On Windows devices:
If your phone has a touch screen, go to Start System tab About.
If your phone doesn’t have a touch screen, go to Start Settings > About.
community help speech bubble
Not found your answer?
Find it in the EE Community
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
