4G Go Faster add-on
How do I get the Go Faster add-on?
Just text GO FASTER to 150. We’ll text you back with a few short steps to follow.
What is the Go Faster add-on?
This add-on gives you access to our fastest 4G speeds in the UK. Access to these speeds depends on the location you’re in and the device you’re using.
Will this boost my speed abroad?
No. This speed boost will only give you access to our fastest 4G speeds in the UK.
Is there a minimum term that I need to commit to with this add-on?
No. You can add or remove this add-on from your account at any time by texting STOP GO FASTER to 150.
What happens if I upgrade or move plan while I have this add-on?
This add-on will drop off your account, and you’ll need to re-add it by texting GO FASTER to 150 again.
I’m on a Max plan. Can I get this add-on?
No. You already have this benefit built into your plan, as well as access to the BT Sport app and access to five additional 'roam like home' countries: the USA, Canada, Mexico, Australia and New Zealand.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
