How to uninstall the clone phone app
You can remove the Clone Phone app at any point, but if you are a Clone Phone Loaded or Fully Loaded customer, you'll need to de-activate the Lock & Wipe feature on the app first.
On Android devices you'll need to go to Menu > Settings > Applications > Manage Applications. After clicking on the app, you'll see a screen full of data about space used and permissions. Click on the uninstall button.
See the full terms and conditions >
See all Clone Phone Help >
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
