Change your plan today and download, browse and stream to your heart's content
You’re seeing this as we sent you a text with our plan recommendation based on your data usage or spending pattern.
Our 4GEE plans bring you the very best of EE. Get a plan that suits your needs today.
What do you get with our plans?
4GEE Max Plans
  • Up to 40GB data each month
  • Unlimited minutes and texts in the UK - you can also use them in over 50 destinations in EU, Australia, Canada, Mexico, New Zealand and USA
  • 24 months BT Sport app access
  • Our fastest UK speeds
4GEE Plans
  • Up to 10GB data each month
  • Unlimited minutes and texts in the UK - you can also use them in 46 EU destinations
  • UK speeds up to 60Mbps
Essential Plans
  • Up to 2GB data each month
Convinced you’d like to change your plan? Simply reply YES to the text we sent you and we’ll do the rest.
Please note:
  • Your contract length or contract end date will stay the same, the only thing you’re changing is your price plan. You can switch to a different plan in our current range once every 30 days. However, you won’t be able to move to a plan that costs less than the plan you originally joined.
  •  We’ll send you a text as soon as your new plan starts. This will always be on your next bill date. However, if you change your plan on your actual bill date, the plan won’t begin until your following bill date.
  •  If you’re moving to a Max plan, you don’t need to cancel your BT Sports subscription. Your subscription will automatically end on your next bill date.
  • Once your plan has changed just log into the BT Sport app with your existing BTID and you’ll be up and running.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
