Understanding data usage
  • Go to section
There are a few things worth knowing about how you use data with EE.
Can I ever go over my data allowance?
No, you can’t go over your data allowance. We’ll text you when you’ve used 80% and then again when it runs out – there are no hidden charges.
If you do use up your data you can always buy more to see you through.
Why is my data usage sometimes more than I've downloaded?
When content providers state the file size of their content, it may take up a little bit more of your data to download that file. This is because of encryption and addressing data – the ‘headers’ on each packet of data – which can be up to 10% of the total file size.
For instance, if an image is said to be 100 megabytes, it may take up to 110 megabytes of data to download that file to your device.
At EE, we do what we can to limit the amount of data you use when downloading content in the UK, for example by not counting all of the ‘DNS’ data that’s used up every time you access the internet.
Quick ways to check your data and get more
You can:
    log in to My EE
    text AL to 150 free from your EE device
    go to add-on.ee.co.uk on your EE device
Remember, we’ll always send you a text to let you know when you’ve used 80% of your data and again when you’ve run out.
Can I use data when I go abroad?
Heading abroad?
You can use your data allowance in 48 European destinations at no extra cost. If you’re heading further afield, you’ll need to buy a roaming add-on to use data while you’re abroad.
> Find out more about costs with our roaming tool
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 17/1/2018
Nikki posted this article. Got a comment? Good or bad, we'd pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
Your online EE bill explained
Why is my bill higher than normal?
