How can I keep my phone safe?
  • Choose Article?
If you’ve recently joined EE or just upgraded, you’ll want to keep your new device looking shiny and new.
Should I insure my new device?
We’d recommend you do – just in case your phone gets damaged, lost or stolen.
We offer two types of insurance:
  • 1
    Full cover
    You’re covered for repairs or a replacement if your device is lost, damaged or stolen.
  • 2
    Damage cover
    You’re covered for repairs or a replacement if your device is damaged.
We can only insure devices bought directly from us either online, on the phone or in store.
We do insure some SIM only phones, but it depends on the model.
Remember: We can’t offer insurance after your phone is lost, damaged or stolen.
To get insured, either:
    add insurance to your plan at the checkout if you’re joining EE, upgrading or adding another device to your plan
    call 150 from an EE phone or 07953 966 250 from any other phone if you’ve already upgraded and would like insurance
Can I keep my insurance if I upgrade?
No. You’ll need to take insurance for your new device when you upgrade. You can do this by:
    adding insurance to your basket if you’re upgrading online
    telling us you want insurance when you upgrade on the phone or in store
    calling 150 from an EE phone or 07953 966 250 from any other phone after you’ve upgraded
Remember: If you’re an Orange or T-Mobile customer upgrading to an EE plan, you won’t be able to renew Clone Phone Fully Loaded, Tablet Care, or Orange Care.
Good to know
We’ve teamed up with Lookout Mobile Security to help keep your phone or tablet safe.
> Find out about Lookout Mobile Security
How can I protect my SIM?
You can set up a SIM PIN to protect your SIM should it ever be lost or stolen.
It’s a four-digit code that you’ll be asked to enter every time you restart your device or remove your SIM.
To set up a SIM PIN:
On an iOS device
  • 1
    Go to Settings, tap the Phone option and then SIM PIN
  • 2
    Switch SIM PIN on
  • 3
    Enter the default SIM PIN (1111 or 1210 for T-Mobile customers)
  • 4
    Select Change PIN
  • 5
    Re-enter the default PIN when prompted
  • 6
    Then enter a new four-digit PIN
  • 7
    Re-enter your new PIN when prompted
On an Android device
  • Go to Settings, tap the Security option and then Set up SIM card lock
  • Check Lock SIM card
  • Enter the default SIM PIN (1111 or 1210 for T-Mobile customers)
  • Select Change SIM PIN
  • Re-enter the default PIN when prompted
  • Then enter a new four-digit PIN
  • Re-enter your new PIN when prompted
For any other operating systems, please refer to your device’s instruction manual.
Give us a call
Give us a call
Call now
150
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 13/11/2017
Sharelle posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
What happens to my extras and discounts when I upgrade?
Can I get an Annual Upgrade?
