How can I fix problems with the EE TV app on my tablet or phone?
  • Go to section
Having problems watching EE TV on your tablet or phone? You’ve come to the right place.
Check your tablet or phone is connected to your router
First, check your tablet or phone is connected to the same router as your EE TV – look in your device’s settings.You may need to move a bit closer to make sure you’re getting a good WiFi signal from your router, you should have two bars or more.
Check your EE TV WiFi signal strength
Check there's a good signal strength between your EE TV and router if you're using WiFi:
  • 1
    Press Menu on your EE TV remote
  • 2
    Use the arrow buttons to go to TOOLS & HELP > STATUS and press OK
  • 3
    You’ll see your WiFi status – above 80% is good and 60% is OK
Still having problems with WiFi?
> Check our WiFi set-up guide
If you’re still having WiFi problems, you could trying using a wired (Ethernet) connection or consider buying some powerline adaptors to connect.
> Find out more
Move closer
If you’re having WiFi connection problems, you may need to move closer to your router. It doesn’t matter how close your device is to your EE TV box.
Check your EE TV isn't in eco mode (deep sleep)
When you're not using your EE TV box, it goes into a deep sleep – you'll know as the light on the front turns off. To wake it up, press the standby button on your remote control.
To stop your EE TV box going into eco mode:
  • 1
    Press MENU on your EE TV remote
  • 2
    Use the arrows to go to TOOLS & HELP > MULTI SCREEN
  • 3
    Tick the EE TV app user box
Close and re-open your EE TV app
Try closing and re-opening your EE TV app:
iPhone or iPad
  • 1
    Double click Home and swipe left or right to find your EE TV app
  • 2
    Swipe up on the apps preview to close it
  • 3
    Re-open the app
Android phone or tablet
  • Open Settings, choose Apps and tap Running
  • Choose EE TV and tap Stop or Force Stop
  • Re-open the app
Still having problems? Try turning your device off and on again.
Reboot your EE TV and router
Try switching off then unplugging your EE TV from the mains. Wait 30 seconds before plugging it back in and switching on again. Still not working? Try doing the same with your router.
Repair your EE TV app with your EE TV
> Find out how to repair your EE TV app
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 17/1/2018
Sharelle posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
How do I Flick and Fetch with EE TV?
How do I contact suppliers for EE TV on demand apps?
