Connect to EE TV using wireless
  • Go to section
How do I connect to EE TV using wireless (WiFi)?
A wireless connection is great if you can’t put your EE TV box near your route.
Switch from a wired to a wireless connection
If you’re switching from a wired connection, you’ll need to update your NETWORK & CONNECTION settings.
  • 1
    Press MENU on your EE TV remote
  • 2
    Use the arrow buttons to go to TOOLS & HELP > SETTINGS > NETWORK & CONNECTION
  • 3
    Select Change to WiFi
  • 4
    Choose your wireless network from the list – the code name is on a sticker on your router
  • 5
    Enter your password – it’s on a sticker on your router
  • 6
    You should be connected
Check your connection
  • 1
  • 2
    Use the arrow buttons to go to TOOLS & HELP > STATUS
  • 3
    Your internet status should be ‘Connected’
Can’t see your wireless network?
    in NETWORK & CONNECTION, press Re-scan
    check your wireless router is turned on
    try turning your router off and on again
    try moving your EE TV box closer to your wireless router if possible
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 13/12/2017
Sharelle posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
How do I connect to EE TV using an Ethernet cable?
Can I use powerline adaptors with EE TV?
