EE TV lights explained
  • Go to section
Green light – active
Your EE TV box is on.
No light – deep sleep or off
Your EE TV box may be in deep sleep mode if you've not used it for a while, or may not be plugged in.
    press the power button on your remote control – after a minute or so your EE TV will come back to life
    check your power cable is plugged securely into your EE TV box
    check your power socket is turned on and working – try plugging something else in
If you're using Replay and Restart on your EE TV, it won't go into deep sleep.
Red light – standby
Red light – standby
Press the standby button on your remote to wake it up. If the red light remains:
    try pointing your remote directly at your EE TV box or move a bit closer
    check there’s nothing in-between your remote and EE TV box
    turn your EE TV box off at the mains, wait 30 seconds, turn it back on and try using your remote again
    check your batteries haven't gone flat – try new ones
Flashing green light
This shows your EE TV is starting up. It will turn solid green after 30 seconds. If it continues to flash, your set top box may be trying to update firmware. Leave it for 30 minutes.
If it flashes for more than 30 minutes, reboot your EE TV box. Still not starting? Get in touch >
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 20/12/2017
Sharelle posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
EE TV settings explained
EE TV icons explained
