How do I connect to EE TV using an Ethernet cable?
  • Go to section
It's easy to connect your EE TV using an Ethernet cable.
  • 1
    Plug your Ethernet cable into the port shown on the EE TV box.
  • 2
    Plug the other end of the cable into a spare yellow socket on your Bright Box router.
How do I update my EE TV settings?
If you’re switching from a wireless connection, you’ll need to update your NETWORK & CONNECTION settings.
  • 1
    Press MENU on your EE TV remote.
  • 2
    Use the arrow buttons to go to TOOLS & HELP > SETTINGS > NETWORK & CONNECTION
  • 3
    Select Connect via ethernet
Useful tip
If you get this message:
Please plug in your Ethernet cable to connect
check you've connected your EE TV to a yellow socket on your Bright Box router.
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 16/1/2018
Simon A posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
What’s the EE TV Interactive Setup Guide?
Connect to EE TV using wireless
