How do I update my EE TV set top box software?
  • Go to section
From time to time, we'll update the software on your EE TV with new features and services.
Update software for your EE TV box
We’ll do this automatically as updates become available. Usually, it’ll happen while your box is in standby mode, but occasionally, you may see your box update while you're watching TV. It should only take a few minutes.
If you have problems with picture or sound after an update, try resetting your EE TV box
  • 1
    Press MENU on your EE TV remote
  • 2
    Use the arrow buttons to go to TOOLS & HELP and press OK
  • 3
    Go to SETTINGS > ADVANCED SETTINGS
  • 4
    Enter your PIN and press OK
  • 5
    Press Reset settings and your box will restart
Update the EE TV app on your phone or tablet
Go to your device’s app store to check for any updates and download the new version of the EE TV app for free.
Good to know
You should get a message on your TV to tell you when it’s time to update your app.
How to check which software version your EE TV box is running
  • 1
  • 2
  • 3
    Go to SETTINGS > STATUS
  • 4
    From here, you can check your upgrade and software version.
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 15/12/2017
Sharelle posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
How can I change my TV region and PIN on EE TV?
Accessibility settings on your EE TV
