What’s the EE TV Interactive Setup Guide?
  • Go to section
The EE TV box and router are specially designed to be easy to set up yourself. Follow our six-step guide to get yours up and running
How to set up your EE TV box and router
Step 1 – Check your EE TV box
Everything you need should be in the box of EE TV goodies we sent you – check that you’ve got everything before you start:
    EE TV set-top box
    power plug
    ethernet, aerial and HDMI cables
    EE TV remote control and batteries
    aerial adaptor
    quick start guide
Step 2 – Connect your aerial
If you already have a working aerial cable, connect it to the IN socket on your EE TV box.
If you have an aerial wall socket but no cable, use the aerial cable and the adaptor we sent you with your EE TV.
If you already receive these channels on these channel numbers, you have the correct type of digital aerial for EE TV:
    ITV2 on channel 6
    Dave on channel 12
    ITV3 on channel 10
    Music on channel 18
Your aerial
No rooftop aerial? You can find a registered fitter at getmedigital or CAI Trade Gateway.
It’s possible to use an indoor aerial, but the signal may not be strong enough.
If you use a communal aerial in a block of flats you may need to check with your landlord or housing association.
In both cases, if you already get Freeview, you’re probably okay for EE TV.
Step 3 – Plug in your HDMI cable
Got an HDMI socket in your TV?
Plug the HDMI cable we sent you into your TV and your EE TV box.
No HDMI socket in your TV?
You’ll need a SCART cable. You can use your own or get them from us >
Step 4 – Connect EE TV to your router
Plug your Ethernet cable into your EE TV box. Then plug the other end into any spare yellow socket on your Bright Box  router.
No connection? Try plugging in a laptop to make sure your cable’s working properly.
Once your EE TV box is switched on, you’ll have the option to connect using WiFi. You’ll need your password and username to do this – they’re on a label on your router.
If your router and your TV are too far apart to get a good signal over WiFi, you could try using powerline adaptors >
Step 5 – Switch on
Put the AAA batteries in the back of the remote control.
Switch your EE TV box on.
Press the red power button – top right on your remote. The green light on the front of your EE TV box will flash. Once it’s solid green, your onscreen start-up will begin.
Use your remote to follow the instructions onscreen.
Step 6 – Turn on, tune in
Press the ‘SOURCE’, ‘AV’ or ‘INPUT’ button on your TV remote.
Wait a few seconds. If you don’t see an EE screen, press the button again. You may have to press the button several times until you’ve found the name of the socket that you used to connect your EE TV Box to your TV set in step 2.
You’ll then see the EE TV screen... you’re all set to enjoy EE TV.
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 16/1/2018
Mark posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
Can I get EE TV assisted installation?
How do I connect to EE TV using an Ethernet cable?
