Home Broadband - Technical settings
  • Go to section
How to reset your browser, check proxy server settings and clear cookies and cache
Reset your browser
From time to time, it can help to reset your browser. Here’s how:
Internet Explorer
    click Tools > Internet options
    select Advanced > Reset
    select Delete personal settings – this is optional, but can often help
    click Reset – your browser will reset
    click Close
    close and re-open Internet Explorer to check if you've fixed the problem
Firefox
    click the Firefox button
    go to Help > Troubleshooting Information
    select Reset Firefox
    Firefox will restart
    you can now check if you've fixed the problem
Safari (Apple Mac)
    open the Safari menu
    click Reset
    Safari will restart
Google Chrome
    go to Menu > Settings
    choose Show advanced settings
    then Reset settings > Reset settings
    finally, select Reset
Check your proxy server settings
Using a work laptop at home, and having problems viewing web pages? Here’s how to check if proxy server settings are causing the problem.
If you also use work VPN software, you'll usually need your proxy settings turned on while connected to VPN, and off while not.
Internet Explorer and Google Chrome
    select Connect > LAN settings
    remove checks from all boxes and click OK
Firefox
    choose Menu > Options and Options again
    select the Network > Settings
    select No proxy > OK
Apple Mac
    click the Apple icon in the top left of the menu bar, then System Preferences
    click Network
    select AirPort (or Ethernet depending on the type of connection you're using)
    click Advanced
    click on Proxies
    remove any ticks in the check boxes under Select a protocol to configure
    make sure Bypass proxy settings for these Hosts & Domains settings only contain local, 169.254/16 (or that the field is blank)
    click OK, then if you've made any changes, click Apply Now
    on your keyboard, press Apple, and the letter Q to quit System Preferences
Clear cookies and cache on your computer
Clearing your browsers cookies and cache can help if you're having problems with web pages loading slowly. It can also help if you're being redirected to our Nearly there... or parental control page while setting up your Home Broadband.
Internet Explorer
    click Tools > Internet Options
    under Browsing history, click Delete
    click to remove the check from Preserve Favourites website data
    click to check remaining options
    select Delete
    your cache and cookies will be cleared
    click OK to close Internet options
Firefox on Windows
    open the Firefox menu
    select Options
    select Advanced > Network
    in the Cached Web content field, select Clear Now
Google Chrome on Windows
    click the Chrome menu in your browser's toolbar
    select Tools > Clear browsing data...
    in the box that appears, select to Obliterate the following items from the beginning of time
    then click to check all options you want to delete – make sure cookies and cached images are included
    click Clear browsing data
Safari on a Mac
    click on Safari in your Mac's menu bar and select Preferences
    select Privacy
    click Remove All Website Data...
    click Remove Now to confirm that you want to remove all data
Firefox on a Mac
    from Firefox, open the menu
    click on Preferences
    select Privacy > clear your recent history
    in the time range... menu, select Everything
    open the Details menu (if required)
    select all the items you want to clear, making sure that cookies and cache are included
    click Clear Now
Google Chrome on a Mac
    in the box, select Obliterate the following items from the beginning of time
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 9/1/2018
Mark posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
What's a WiFi Booster Pack?
What’s 4GEE Home?
