How can I check my internal home wiring?
  • Go to section
Having problems making or receiving calls on your phone at home? Here’s how to check if your service is working from your main BT socket, and your test socket.
Main phone socket
Main phone socket
Start by finding your main socket – it's the socket your phone line connects to as it enters your home. It should look like one of these:
Next:
  • 1
    Remove anything plugged into the socket, e.g. broadband filters, line doublers, or extension cables
  • 2
    Connect a phone (ideally a corded handset, and not a DECT or portable phone) directly to the socket
  • 3
    Pick up the handset, and try to make a call
Test socket
Test socket
If your phone works in your test socket, there are a few tests you can try:
Next:
  • 1
    Unplug your phone from the phone socket
  • 2
    Carefully unscrew the two screws on the bottom half of the faceplate
  • 3
    Gently remove the lower half of the faceplate – be careful not to disturb any cabling behind it (if wires are already loose behind the faceplate, this could be the cause of your problem)
  • 4
    Plug your phone into the test socket
If your phone works in your test socket, check these elements:
    disconnected extension sockets and cables. Check your extension is plugged in correctly, and nothing has become dislodged
    damaged extension sockets and cables. You may need to replace extension kits or consider using a cordless phone
    faulty equipment connected to your line. If you can, test all your equipment one by one in your test socket. Once you've found the faulty equipment, remove it from your line
    faulty broadband filters. Check all your filters with a phone you know is working
    broadband routers. If you only get the problem when you connect your broadband router to the line (and you've already checked with a spare filter), let us know.
    too many phones connected. As a general rule, phone lines are designed to work with up to four phones or devices connected to the line. If you've got more, test with only four devices connected
Still not working? Take a look at our tips on how to fix home phone faults.
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 14/12/2017
Nikki posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
Home phone - getting started
How can I fix home phone faults
