I’ve received a ‘network busy’ error message – what does this mean?
  • Go to section
If you get a "network busy" error message, this means there’s a high volume of use on the network.
A typical reason could be that there’s a major event going on in your area, perhaps a concert or a football match.
it should be a short-term problem, but you may want to try one of the following:
  • try turning your phone off and on again to pick up the strongest local signal
  • you could also try our network status checker to see if there’s a known issue, or to report a problem
Give us a call
Give us a call
Call now
150
(Free - 25p per call on PAYG)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 9/1/2018
Sharelle posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
My phone has no signal – what should I do?
How can I get a better signal?
