How much does it cost to use my voicemail while I'm abroad?
  • Go to section
Find out more about using your voicmail when you're away from the UK.
If you're travelling within the EU, you can use voicemail just as you would at home.
In non-EU countries you'll be charged a standard per-minute roaming call rate depending on what plan you're on.
> Get a personalised roaming cost with our roaming calculator
Give us a call
Give us a call
Call now
Free - 25p per call on PAYG
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 8/1/2018
Andrew posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
How much does it cost to use data, send texts or make calls when you’re abroad?
Why have I been charged to make calls in a country I haven’t visited?
