Roaming on EE Business
Free EU roaming for our customers
From 15 June 2017 you can take your minutes, texts and data with you, to use anywhere in the Europe Zone
When it comes to running your business, we know being connected at all times is a must.
From 15 June EE small business plans will include roaming while in our Europe Zone.
So if you’re planning a change of climate any time soon, rest assured you’ll still have your business at your fingertips.
Check if you're set up
To check if your phone's set up to use abroad text ROAMING to 150 before you go
What happens if I...
...run out of data?
If you use up your UK data allowance while you're abroad in the EU, you can buy a data add-on just like you would in the UK. From 15 June add-ons will be the same price across the UK and the EU. Business Connect customers will be charged the same out of bundle rates as in the UK.
...use up my minutes and texts?
From 15 June you'll be charged the same rate as in the UK for any calls or texts outside your allowance.
