Checking my EE TV WiFi signal strength
To check your WiFi signal strength is good, follow the steps below:
  1. Press the MENU button on your EE TV remote.
  2. Press the up arrow on your remote (that's the one above OK) to highlight the menu.
  3. Move over to TOOLS & HELP by pressing the right arrow on your remote.
  4. Now press the down arrow to highlight STATUS and press OK.
  5. The quality of your WiFi connection will be displayed.
Above 80% is good and 60% is OK. If quality is low and you're having problems using On Demand content, see our guide to improving wireless performance.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
