Setup map
What’s in the box?
An EE TV box
A power unit and cable
This does exactly what you’d expect. It connects your EE TV box to your electricity supply.
2 x AAA batteries
For use in the remote control.
An aerial cable
This is sometimes known as an RF cable. You may need it to connect your rooftop aerial to your EE TV box.
A remote control
An ethernet cable
This cable connects your EE TV box to your Bright Box.
An HDMI cable
This cable connects your EE TV box to your HD television via a spare socket on the back or side of your television.
An aerial adaptor
You’ll need this adaptor if the end of your aerial cable won’t connect to the IN socket on your EE TV box.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
