Turning on Replay and Restart on your EE TV
With EE TV you can choose between Replay mode and four channel recording.
  • Replay: lets you set up your box to record anything that has been on your six favourite channels during the last day. Replay will keep it for you for 24 hours. You'll also be able to record up to two programmes at the same time.
  • four channel recording: switching off Replay lets you record up to four programmes at the same time
You can check and change your settings from your REPLAY settings.
Check Replay settings
To check your Replay settings:
  1. Press the MENU button on your EE TV remote
  2. Press the up arrow on your remote (that's the one above OK) to highlight the top menu
  3. Move over to TOOLS & HELP by pressing the right arrow on your remote
  4. Press the down and right arrow to highlight SETTINGS and press OK
  5. The settings screen will appear
  6. Move right (using the right arrow) to highlight REPLAY
  7. From here you can check and update your Replay setting
  8. In the example below, Replay is on, with a Replay duration of 1 day - the next section looks at how you can change Replay settings
Turning on Replay settings
If Replay is off:
  1. Press OK to change settings
  2. Use the right arrow on your remote to select how long you'd like Replay to record programmes for
  3. You can choose from 6 HOURS, 12 HOURS, 18 HOURS or 1 DAY
  4. Press down and OK to CONFIRM
  5. Next, you'll be asked to choose which group of channels EE TV will use for Replay
  6. Replay is available on HD Channels (High Definition) or SD channels (Standard Definition) channels
    Note: it's not possible to play HD content on all tablet or phones. See our supported devices guide for more help.
  7. Choose HD Channels (High Definition) or SD channels (Standard Definition) and press OK
  8. Next, select your favourite channels using the up and down arrows on your remote and then OK
  9. When you've chosen 6 channels, press OK to confirm
  10. If you see a message saying you don't have enough storage, you may need to delete some of your recordings
  11. That's it - your EE TV will start recording programmes, so they're available for Replay
  12. You can always change your Replay channels later
Check your Replay group and Replay channels
The Replay group and Replay channels you've chosen are displayed in the Replay settings menu.
Changing your Replay group
Replay group lets you change your Replay channels, for example from SD channels (Standard Definition) to HD Channels (High Definition).
If you select this option, you'll see a message indicating HD Channels aren't available for Replay.
Changing your Replay channels
To change your Replay channels:
  1. Press the down arrow to highlight Replay channels and press OK
  2. First, remove any unwanted Replay channels to make space for your new channels
  3. Using the up and down arrows on your remote, highlight the channel and pressing OK to remove the tick
  4. Now, select the new channels that you'd like to make available for Replay
  5. When you've chosen your 6 channels, press OK to confirm
  6. If you see a message saying you don't have enough storage, you may need to delete some of your recordings
  7. That's it - your EE TV will start recording programmes, so they're available for Replay
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
