Apple Mac - set up a wireless connection
Before you start
To connect using wireless, you'll need your router's wireless network name and wireless password. You'll find these printed on a sticker on the bottom or back of most routers, as seen in the example below.
It can also help to:
  • Move close to your router while setting up the connection
  • Unplug an Ethernet cable (if you've already set up a wired connection)
Connect to your router
To connect an Apple Mac to your router, follow the steps below:
  1. Click on the AirPort Apple AirPort icon icon in your Mac's menu bar
    AirPort icons in Mac's menu bar
  2. A list of wireless networks will be shown in the network list
  3. Select your wireless network - in the example below ours is 5GHz-EE-1a2b3c - you'll find yours printed on your router
  4. If you can't see any wireless networks, try moving closer to your router and check it's turned on
    BrightBox router listed in network settings
  5. You'll be prompted to enter your password - this is your wireless password which you'll also find printed on your router
  6. It may help to select the Show password option so you can see what you're typing
    Enter the WPA password for the connection.
  7. AirPort will connect to your router
    Connecting to network...
  8. Wait a few seconds - the AirPort icon will change to black (or black and grey)
    AirPort icon in Mac's menu bar
Error after entering security key
If you get an error while trying to connect:
  • Try setting up the connection again, checking you're entering your security key correctly. You'll need to enter the dash (-) if you have a Bright Box router.
  • Restart your router and computer and then try to set up the connection again
Exclamation mark in AirPort icon
If you're connected to your router, but are unable to view web pages or use the Internet you may see an exclamation mark inside the AirPort icon. See one of our guides below to check if there's a problem with your broadband connection.
  • Bright Box 2
  • Bright Box 1
  • Netgear router
  • Livebox
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
