How to connect your Nintendo Wii
To connect a Nintendo Wii to your router, follow the steps below:
  1. Go to your Wii console's main menu
  2. Click the Wii button in the lower left corner
    Wii menu
  3. Click Wii Settings
    Wii Settings
  4. Click the right facing arrow
    Wii system settings
  5. Click Internet
    click Internet
  6. Click Connection Settings
  7. Select a connection indicated as None - in the example below we can choose Connection 1
    Click Connection 1
  8. Click Wireless Connection
  9. Click Search for access point
  10. The Wii console will search for an access point
    Searching for an access point
  11. Click OK
    Choose the access point you want to connect to
  12. Your router will appear in the list of available wireless networks
    Choose your router
  13. Click to select your router
  14. Click on the Input the password or key field
    Click on the 'Input the password or key' field
  15. Click to enter each character of the security key
  16. Click OK
    click OK
  17. Click OK
    click OK
  18. Click OK to save settings
    click OK
  19. Click OK to start the connection test
    click OK to start a connection test
  20. The Wii console will check if it's connected to your router
    testing connection
  21. If the connection test is successful internet setup is complete - your Wii console is connected
    The connection test was successful
  22. Finally, choose if you'd like to update your Wii console. If you would, click Yes and follow the onscreen prompts
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
