Smart TV - set up a wireless connection
This guide shows you how to connect your Smart TV to your broadband wireless router.
Getting started
To connect your Smart TV or set top box to your broadband router using a wireless connection, you'll need:
  • a wireless enabled Smart TV or set top box
  • a working broadband service - check this by using a computer or tablet before you start
  • a wireless router that's in range of your Smart TV
  • your wireless router's wireless network name and wireless password - you'll find them printed on a sticker on the bottom or back of most routers, as seen in the example below:
If you're setting up your Smart TV for the first time or you just need help entering wireless settings, jump to step 2.
If not, we'll show you how to open wireless settings on your Smart TV in step 1.
Step 1 - open wireless settings
If you've recently joined EE broadband, have received a new router or decided to change your wireless network name, you'll need to set up a new wireless connection on your Smart TV. To do this:
  1. Open your TV's menu - the button may be labelled Menu, Home or similar
  2. Open the Settings menu
  3. Choose Network, Network Settings or Network Connection
  4. Choose to set up a wireless connection
Now go to step 2 for help entering your wireless settings.
Step 2 - enter your wireless settings
  1. If you're given the option, don't select to set up the connection using WPS
  2. A list of wireless networks will be displayed
  3. Choose your router's wireless network name using the down arrow on your remote, e.g. EE-1a2b3c
  4. You'll be asked to enter your router's security key or wireless password
  5. Enter this using the virtual onscreen keyboard - the up, down, left and right arrows on your remote will let you highlight the letter, number or character, then use the enter button to select
    Tip: Select symbol, !@# or similar from the on screen keyboard if you need to enter a character that isn't displayed. Our Bright Box wireless router security passwords use the minus character (-) for example.
  6. Once you've entered the security key select Enter, Done, OK, Complete or similar
  7. Your TV will connect to your router, check the Internet connection and confirm that you're connected
If you get an error while setting up your connection, try entering the security key again or see our wireless troubleshooting guide.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
