4G speed-what you can expect
  • EE
  • Orange
  • T-Mobile
If you want to know whether 4G is faster than 3G, the simple answer is yes - and usually in a knock-your-socks-off way.
We're not keen on too much technical jargon here at EE, but it could be as quick as ADSL broadband at home - while you're out and about.
Sounds good... so how quick is it?
There isn't a simple answer, unfortunately, as 4G performance depends on things like...
  • What device you're using
  • How near you are to a 4G mast
  • The number of people on the network
Check out our video to see how much 4G could speed up your digital life.
Brace yourself for some geek-speak...
Here's the technical bit. Average 4G download speeds are likely to be between 8 and 10 megabits a second (Mbit/s), with possible instances of up to 40 Mbit/s.
Typical upload speeds are between 5-6Mbit/s, with possible instances of up to 15Mbit/s.
Another technical word that might help make this 4G thing clearer is latency - the time it takes the network to respond to your action.
Typical 4G latency is only 60-70 milliseconds (ms), while 3G latency is typically 100-125ms. You can really appreciate the difference if you're flicking through webpages or playing online action games.
Was this article helpful?
Thank you.
GETTING THE MOST FROM EE
Services and offers we have for you
New to EE? Use our get started guides
Follow our step-by-step guides to help you get up and running with EE.
Discover more with our video guides
Watch our help and support videos to get the most out of EE and your phone.
Manage your account with My EE app
Keep track of your usage, manage your add-ons or pay your bill on the move.
Join the EE Community now
See what people are saying in the EE Community - get involved or get advice.
