About signal boost from Orange
  • EE
  • Orange
  • T-Mobile
Signal Boost was available to Orange customers on selected Android, BlackBerry and Nokia phones but is no longer available to purchase. If you already have Signal Boost, this article explains:
  • What Signal Boost is,
  • How to set up a phone with Signal Boost
  • Where you can purchase Signal Boost
  • Further bitesize information
Some people struggle to get a good network signal at home, Signal Boost allows Orange customers with a compatible handset to boost their signal indoors.
If you have Signal Boost installed on your handset, you can connect to the EE network through your home WiFi to give you great reception around the house. All you need is an eligible handset and a home broadband connection with WiFi.
Setting up Signal Boost on your handset
If you have an eligible handset, you can follow the simple set up process below:
Once it’s up and running all you have to do is leave WiFi active on your phone and you’ll be able to send and receive calls and texts as normal.  Using Signal Boost doesn’t cost any extra – calls and texts are charged at your usual plan rates.  To use the internet on your phone, you’ll need to use your home WiFi to use data.
Where can i get Signal Boost?
Signal Boost is no longer available to purchase, but we’re working on new ways to help you stay connected in more places.
Further information
Does it matter who my broadband provider is?
No, Signal Boost simply uses your Broadband Wi-Fi signal and it doesn’t matter who supplies the broadband.
How many Signal Boost phones can be used at any one time?
This depends on your broadband speed.  You need a broadband speed of around 80Kb/second for a call.  If your broadband is faster than 240Kb/second you can connect up to three calls at the same time.
How can I tell on my bill which calls were made using Signal Boost?
Calls made using Signal Boost will be marked as ‘Homezone’ on your bill.  We use the term Homezone to describe the coverage that is provided by Signal Boost.
What happens if I’m on a call and move in or out of range of my Wi-Fi?
As long as your phone has Signal Boost coverage or an EE signal, your call will continue uninterrupted.  If your phone can’t pick up either of these signals whilst on the call, the call will disconnect.
Was this article helpful?
Thank you.
Getting the most from EE
Services and offers we have for you
