Signal Box
Some people struggle to get a good network signal at home – things like thick walls, basements and certain types of glass can reduce your signal.
Signal Box is a device that uses your home broadband connection to give you great reception around the house. It plugs into your broadband router and creates a link to our network to provide indoor coverage.
It works by providing 3G coverage with a range of about 15 metres, so anyone with access can make a call just as normal. Customers on Orange, T-Mobile or EE can use the same box.
You'll need a minimum fixed broadband download speed of 512kbps and an upload speed of 256kbps. You can check your speed at www.speedtest.net. It’ll work no matter which Broadband provider you use.
You'll also need:
  • a spare Ethernet port in your router
  • a spare power supply near your router
  • a 3G compatible phone on EE.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
