Bright Box 2 Wireless Router - change admin password
You can change the password you use to log in to your Bright Box 2 from ADVANCED settings. To do this from a computer connected to your Bright Box:
  1. Go to 192.168.1.1
    Enter 192.168.1.1 into browser address bar
  2. The router's login screen will open
    Router's admin pages
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
    Bright Box 2 sticker
  4. Click LOGIN
    Enter the username and password for the router's admin pages
  5. The STATUS page will open
    status page
  6. Select ADVANCED from the menu and click ACCEPT
    Select ADVANCED and then choose ACCEPT
  7. Select System and then Password Settings in the left hand menu
  8. Enter the current password for your Bright Box - you'll find this on the sticker on the bottom of your router
  9. Enter your new password, and then re-enter to confirm
  10. Click SAVE SETTINGS
    Password Settings page
  11. Your new password will be applied.
    Applying changes. Please wait. The process may take up to 30 seconds.
  12. You can now login to your router's admin pages using your new password
If you forget your new password, don't worry. Simply return the router to factory default settings.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
