Bright Box 2 Wireless Router - change settings to ADSL using the Migration Wizard
You may need to use the Migration Wizard to update settings if:
  • You're moving house and your new line doesn't support Fibre Broadband
  • You're checking settings and they don't appear to be correct
  • You've been fiddling, and want to reset your broadband settings (but not all your router settings)
The steps below show you how.
Log in to your router's admin pages
From a computer connected to your Bright Box 2:
  1. Go to 192.168.1.1 (opens in a new tab or window)
    Enter 192.168.1.1 into browser address bar
  2. The router's login screen will open
    Router's admin pages
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
    Bright Box 2 sticker
  4. Select LOGIN
    Enter the username and password for the router's admin pages
  5. The STATUS page will open
    status page
  6. Select BASIC from the menu
    Select Basic from the EE menu
  7. Open the Migration Wizard
    Migration Wizard in Broadband Settings menu
  8. Select the Broadband type ADSL
  9. Click APPLY
  10. Click OK
  11. Your new settings will be applied - you'll be asked to wait until your router has restarted
Check your broadband status
  1. When your router has restarted, you'll be redirected to the LOGIN SCREEN
  2. Enter your router's Username and Password
  3. Click LOGIN
  4. The STATUS page will open
  5. After a few minutes, your Broadband Username will be updated from readytoconnect@fs to your account username
  6. The Broadband Status and Internet Status will display as Connected
    status page
This can take up to 5 minutes - if you're still not connected, see our Bright Box 2 connection guide.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
