Bright Box 2 Wireless Router - disable wireless security
To disable security on the router (for test purposes), follow the steps below from a computer connected to your Bright Box:
  1. Go to (opens in a new tab or window)
    Enter into browser address bar
  2. The router's login screen will open
    Router's admin pages
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
    Bright Box 2 sticker
  4. Select LOGIN
    Enter the username and password for the router's admin pages
  5. The STATUS page will open
    status page
  6. Select BASIC from the menu
    Select Basic from the EE menu
  7. Select Wireless Settings
  8. The WIRELESS SETTINGS page will open
  9. In the Security field, select the option No security
    No security selected from the Security menu
  11. Your settings will be applied
    Applying changes. Please wait. The process may take up to 30 seconds. If you are making wireless changes you may need to reconnect to the wireless network.
  12. Refresh your wireless software and connect using the new security details
We strongly recommend that you use this as a test only, and that you re-enable security once your wireless connection is working.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
