Bright Box 2 Wireless Router - reserve an IP address
You can reserve a fixed IP address for your computer or device on your home network. For example if you're setting up Port Forwarding or Access Control on your Bright Box 2. To do this:
  1. From a computer connected to your Bright Box, go to 192.168.1.1 (opens in a new tab or window)
    Enter 192.168.1.1 into browser address bar
  2. The router's login screen will open
    Router's admin pages
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
    Bright Box 2 sticker
  4. Click LOGIN
    Enter the username and password for the router's admin pages
  5. The STATUS page will open
    status page
  6. Select ADVANCED from the menu and click ACCEPT
    Select ADVANCED and then choose ACCEPT
  7. Select DHCP in the left hand menu
    Select DHCP from the left menu
  8. Scroll to the bottom of the page
  9. In the ADDRESS RESERVATION field, click Add reserved IP
    Click Add Reserved IP
  10. A list of computers (or devices) currently connected (via DHCP) will be displayed
  11. Find the device you want to reserve an address for and click Add
  12. If you can't see your device, check it's connected to your Bright Box 2. Or, you may have already reserved an IP address for the device?
  13. In the last IP address field, the current IP address assigned to the device will be listed.
  14. If required, you can change this to any number between 2 and 254
  15. Click SAVE SETTINGS
  16. Your IP address will be reserved
If you changed the IP address, turn your router off then back on. Your computer will then get its new IP address.
Manually reserving an IP address
You can also select to Manually Reserve an IP address.
  1. In the ADDRESS RESERVATION field, click Add reserved IP
  2. Select Manually Reserve
  3. Enter the IP address you require
  4. Enter the MAC address of your device - this needs to be the Ethernet or Wireless MAC address depending on how you want to connect the device
Turn your router off then back on to ensure the address is available for your new device.
Edit or delete a fixed IP address
Edit or Delete a fixed IP address at any time from the ADDRESS RESERVATION field on the DHCP page:
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
