Bright Box 2 Wireless Router - set up port forwarding
You can set up Port Forwarding on your Bright Box 2 so that certain types of data are sent to a specific computer, device or server connected to your home network. This is useful if you're having problems using a particular online game or maybe if you're an advanced user running a web server from your home network.
Before setting up a Port Forwarding rule, it's a good idea to reserve an IP address for your computer (or device).
Open the Port Forwarding menu
From a computer connected to your Bright Box.
  1. Go to 192.168.1.1 (opens in a new tab or window)
    Enter 192.168.1.1 into browser address bar
  2. The router's LOGIN SCREEN will open
    Router's admin pages
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
    Bright Box 2 sticker
  4. Select LOGIN
    Enter the username and password for the router's admin pages
  5. The STATUS page will open
    status page
  6. Select ADVANCED from the menu and click ACCEPT
    Select ADVANCED and then choose ACCEPT
  7. From the left hand menu, select NAT and then Port Forwarding
Port Forwarding - popular applications
You can pick from a few applications using the popular applications list. To do this:
  1. Scroll to the bottom of the page
  2. Select your application from the popular applications menu, e.g. FILE TRANSFER SERVER
  3. Select the field that you want to paste the ports to, e.g. 1
  4. Click COPY TO
    Select your popular application and click COPY TO
  5. Enter the IP address of the computer that you want to port forward to
  6. In the example below we reserved the IP address 192.168.1.17 so have entered 17
  7. Click SAVE SETTINGS
  8. Your new rules will be applied.
Port Forwarding - add your own ports
Alternatively, you can add your own port or range of ports. You'll find details of the ports to open:
Once you know which ports to forward:
  1. Tick Enable in the first available field (i.e. No 1)
  2. Enter the IP address of the computer that you want to port forward to
  3. In the example below we reserved the IP address 192.168.1.17 so have entered 17
  4. Select the protocol type i.e. TCP, UDP or TCP & UDP
  5. Enter the Private Ports (or LAN) e.g. 3074 ~ 3074 for one port, or 27014 ~ 27050 for a range or ports
  6. Enter the Public Port - in most cases the value for the Private and Public port are the same
  7. Enter details of any additional ports you want to forward
  8. Click SAVE SETTINGS
  9. Your new rules will be applied.
Delete a rule
To delete a rule, simply:
  1. Click to tick the Delete box next to the rule(s) you no longer require
  2. Click DELETE and then SAVE SETTINGS
    Delete your rule
  3. The rule will be deleted
    Applying changes
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
