Bright Box 2 Wireless Router - set up USB file sharing
Did you know you can connect a USB memory stick or hard drive to your Bright Box router? This guide shows you how to connect your drive to the router and read/write files over your home network. It also shows you how to change settings so you can password protect the drive.
Connect memory stick or hard drive to your router
To connect a memory stick or hard drive to your router, simply:
  1. Plug the USB drive into the USB socket on the back of the router
    USB memory stick connected to Bright Box 2
  2. After a couple of seconds, the drive will become available on your home network
    - Windows - You'll find your drive in Computer, under Network (or My Network Places)
    - Apple Mac - You'll find your drive in Finder under SHARED
    Windows example
    BRIGHTBOX listed under Network
    Apple Mac example
  3. To view your files, click on the monitor icon named BRIGHTBOX2 - your files will display
    Files on storage device shown
If you can't see your drive, try one of the options below:
  • Windows - Click Start and enter \brightbox2 in the Search or Run field
  • Apple Mac - Open Finder, select Go and Connect to Server then enter smb://brightbox2
Set up a password for your drive
  1. From a computer connected to your Bright Box, go to 192.168.1.1 (opens in a new tab or window)
    Enter 192.168.1.1 into browser address bar
  2. The router's LOGIN SCREEN will open
    Router's admin pages
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
    Bright Box 2 sticker
  4. Select LOGIN
    Enter the username and password for the router's admin pages
  5. The STATUS page will open
    status page
  6. Click on the Basic Set-Up tab and select USB File Sharing
    USB file sharing menu option highlighted
  7. In the Security Control field, select Enable
    Enable highlighted in the Security Control menu
  8. Enter a Username and Password - you can leave these as default (i.e. user and password) or enter your own details
  9. Click SAVE SETTINGS
  10. Your new settings will be applied
  11. Next time you view files on your device, you'll be prompted to enter the username and password for the drive
  12. Enter the username and password you saved - by default the username is user and the password is password
  13. The files and folders on your drive will be visible
Compatible drive formats
The following formats are compatible:
  • NTFS
  • FAT32
  • FAT16
Apple Mac HFS or HFS+ file systems are not supported.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
