Bright Box 2 Wireless Router - wired connection
You can connect four computers, games consoles, TVs and more to your Bright Box 2 using an Ethernet cable. Follow the steps below:
Connect the cable
  1. Plug one end of the black Ethernet cable into any of the yellow Ethernet sockets on the back of your Bright Box 2
  2. Plug the other end into the Ethernet socket on your device
To get the fastest possible speeds plug your compatible computer into the GigE port - it's the one on the right.
Check your connection
You can check your connection is working by going to ee.co.uk or any other webpage.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
