Bright Box 2 Wireless Router - change security to WPA
You can change wireless settings to WPA2, WPA or back to the default WPA/WPA2 Mixed Mode settings from the router's admin pages. To do this:
  1. From a computer connected to your Bright Box, go to 192.168.1.1 (opens in a new tab or window)
    Enter 192.168.1.1 into browser address bar
  2. The router's LOGIN SCREEN will open
    Router's admin pages
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
    Bright Box 2 sticker
  4. Click LOGIN
    Enter the username and password for the router's admin pages
  5. The STATUS page will open
    status page
  6. Select BASIC from the menu
    Select Basic from the EE menu
  7. Select Wireless Settings
  8. The WIRELESS SETTINGS page will open
  9. In the security field, make sure WPA is selected
  10. In the WPA mode menu, you can choose the version of WPA you wish to use - default settings are WPA/WPA2 Mixed Mode
    - WPA/WPA2 Mixed mode is compatible with most operating systems
    - WPA offers increased compatibility with older operating systems, but is limited to 54 Mbps
    - WPA2 offers enhanced security, and up-to 300Mbps wireless n speeds and up-to 867Mbps wireless ac speeds on your internet network
    - If you're connected to the 5GHz network, you can also change 5GHz settings from the 5GHz menu
  11. Click SAVE SETTINGS
    Click SAVE SETTINGS
  12. Your new settings will be applied
  13. Refresh your wireless software and connect using the new security details
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
