Bright Box 2 Wireless Router - connect using WiFi protected setup (WPS)
If you regularly set up new connections on your wireless router, it can help to enable WiFi Protected Setup (WPS). This allows compatible wireless software to connect to your router by pushing the WPS button, instead of having to type the security code.
WPS settings are disabled by default, however they can be enabled from the router's admin pages.
How to enable WPS
To enable WiFi protected setup, follow the steps below from a computer connected to your Bright Box 2:
  1. Go to 192.168.1.1 (opens in a new tab or window)
    Enter 192.168.1.1 into browser address bar
  2. The router's LOGIN SCREEN will open
    Router's admin pages
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
    Bright Box 2 sticker
  4. Select LOGIN
    Enter the username and password for the router's admin pages
  5. The STATUS page will open
    status page
  6. Select ADVANCED from the menu and click ACCEPT
    Select ADVANCED and then choose ACCEPT
  7. Open Wireless Settings and select WiFi Protected Setup
    WiFi Protected Setup highlighted from the Wireless Settings menu in Advanced settings
  8. Select the Enable option and click on SAVE SETTINGS
  9. Your settings will be applied
    Applying changes. Please wait. The process may take up to 30 seconds. If you are making wireless changes you may need to reconnect to the wireless network.
  10. You can now connect to your Bright Box 2 using a compatible WPS device - You'll find some examples below
Connect using push button connect
When setting up a wireless connection, you may be given the option to push the WPS button on the router. There's a couple of examples below:
Windows 7
Windows 7 wireless manager software prompting for user to press button on router.
Windows Vista
Windows Vista wireless manager software prompting for user to press button on router.
To set up a secure wireless connection:
  1. Press and hold the WPS button on the router for five seconds
    Wireless button on the top of the Bright Box 2 highlighted
  2. Alternatively, click on the Start PBC button that you'll find in WiFi protected settings
    Start PBC button from WiFi Protected Setup settings
  3. The Intelligent Wireless light on the router will flash quickly
    Intelligent Wireless light flashing green
  4. The wireless software will connect to your Bright Box 2 and set up a secure wireless connection
Connect using the PIN method
When setting up a wireless connection, some wireless software will prompt you to enter the router's PIN to set up a secure wireless connection.
Image showing prompt for PIN for router
You'll find the PIN in the WiFi Protected Settings.
Personal Identification Number (PIN)
Alternatively, the wireless software may give you a PIN for you to enter onto the router's admin pages - an example of a BlackBerry device has been included below:
Image of BlackBerry device showing PIN number
In this case, type the key provided by the wireless device into the WiFi Protected Settings:
Enter PIN and click Connect
If you find you're unable to connect using WPS set up, don't worry. Simply connect by entering the router's wireless password instead.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
