Bright Box 2 Wireless Router - enable or disable wireless
This guide will show you how to check if wireless is enabled on your router and how to enable or disable wireless.
Check if wireless is enabled
To check if wireless is enabled look at the wireless light on the front of the router.Wireless light on Bright Box 2 flickering
If the light is on or flickering, wireless is enabled. If the light is off, wireless is disabled.
Disable (or enable) wireless
You'll need to complete these steps using a wired connection between your computer and Bright Box router.
  1. Go to 192.168.1.1 (opens in a new tab or window)
    Enter 192.168.1.1 into browser address bar
  2. The router's LOGIN SCREEN will open
    Router's admin pages
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
    Bright Box 2 sticker
  4. Select LOGIN
    Enter the username and password for the router's admin pages
  5. The STATUS page will open
    status page
  6. Select ADVANCED from the menu and click ACCEPT
    Select ADVANCED and then choose ACCEPT
  7. Click Wireless Settings from the Broadband Settings menu
    Wireless Settings from Advanced
  8. Select the to Enable or Disable Wireless - in the example below we selected to Disable
  9. Click SAVE SETTINGS
  10. Your changes will be applied
    Applying changes. Please wait. The process may take up to 30 seconds. If you are making wireless changes you may need to reconnect to the wireless network.
Disable an individual wireless network name
If you simply want to disable (or enable) an individual wireless network name (or SSID) on your router:
  1. Select BASIC from the menu
    Select Basic from the EE menu
  2. Select Wireless Settings
  3. The WIRELESS SETTINGS page will open
  4. From here you can select to Enable or Disable Wireless for the specific wireless network name
    Enable or Disable wireless for 2.4GHz or 5GHz
  5. Select your required option and then click SAVE SETTINGS
    Click SAVE SETTINGS
  6. Your settings will be applied
  7. You'll be taken back to the WIRELESS SETTINGS page.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
