Livebox Mini - connection not working
Having problems viewing web pages? Perhaps you're unable to connect to your Livebox or the @ light is flashing? We'll show you some simple steps that fix most problems.
Turning it off and back on again
It's simple, but turning everything off and back on again really does fix most connection problems.
  • Turn your Livebox power off at the mains (or unplug if you don't have a switch)
  • Shut down your computer (or device)
Wait about 30 seconds, then turn everything back on. After a few minutes, check your connection again.
Check your landline phone is working
Start by checking your phone line is working OK.
  1. Plug a phone into the same filter as your Bright Box router is connected
  2. Listen for dial tone (or try to make a call)
  3. If you're unable to hear dial tone, or can hear a lot of noise on your phone line see our guide Home Phone - fixing faults
Account live?
If you're new to EE broadband, check your service is active by logging in to Your Account. Open the track your orders option.
If your connection has suddenly stopped working, log in to Your Account and check your bill. An outstanding balance may have stopped your broadband service from working. See paying your broadband bill if you think that has happended.
Is it plugged in and turned on?
From time to time, power switches can turn off, cables can work their way loose, or even find themselves in the wrong sockets.
Check everything is turned on, and connected to the correct socket. If you're unsure, see our set up guide.
Check your @ light
The @ light helps you to understand if your Livebox is connected to the internet. Match your @ light to one of these options:
Solid green light
Solid green @ light
Great news - your broadband connection is working.
Next step - check you've got a working connection between your computer and Livebox.
Flashing quickly red
Livebox @ light flashing quickly red
If you've already checked your broadband service is live, and restarted your Livebox:
  • Check cable set up. You'll find more help with this in your set up guide.
  • Check filter set up and internal wiring. You'll find more help with this in our filters and extension cable guide.
Flashing slowly amber
Livebox @ light flashing slowly amber
If you've already checked your broadband service is live, and restarted your Livebox check your username and password are correct.
Light is off or dim
Livebox @ light off
  • Power light flashing. Wait a few more minutes and re-check the @ light.
  • Power light solid. It looks like there is a problem. Try returning your Livebox to default settings.
Connection between your computer and Livebox
You can check if you've got a working connection by going to the ee.co.uk website.
For help setting up a connection, see one of our guides below:
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
