Livebox Mini - enable yellow port
By default the yellow port on your Livebox Mini won't work with computers and games consoles. Instead, you'll need to use the red port.
Livebox Mini - yellow port disabled.
This is OK, unless you need two Ethernet sockets. If this is the case, you can enable the yellow socket from your Livebox's admin pages. To do this:
Log on to your Livebox home page
  1. Go to 192.168.1.1
    Enter 192.168.1.1 into your browser
  2. The Livebox home page will load
  3. Under Settings, click Access
    The Livebox admin pages will load
  4. Enter the password admin and click Sign in
    Enter the password admin, and click sign in.
Enable the yellow port, by disabling digital tv
OK, so this sounds a bit odd, but just trust us on this one, it works.
  1. Click Services
  2. Click Digital TV
  3. Under Service configuration, select the Disable option
  4. Click Save
    Disable digital TV
  5. That's it - you'll now be able to use the yellow Ethernet port
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
