Livebox Mini - connect using an Ethernet cable
To set up a wired (Ethernet) connection between your computer and Livebox, follow the steps below:
Connect the cable
  1. Plug one end of your Ethernet cable into the red socket on the side of your Livebox
    Ethernet cable connected to red socket on Livebox
  2. If you'd like to use the yellow port, see Livebox Mini - Enable yellow port
  3. Plug the other end into the Ethernet socket on your computer
    Ethernet cable - connecting to computer
Check your connection
Why not check your connection's working by going to the ee.co.uk website?
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
