Netgear router - connect using an Ethernet cable
To set up a wired (Ethernet) connection between your computer and router follow the steps below:
  1. Plug one end of the Ethernet cable into any of the yellow Ethernet sockets on the router
    Ethernet cable plugged into Netgear wireless router
  2. Plug the other end of the Ethernet socket into the Ethernet socket on the computer
    Ethernet cable plugged into laptop
Check your connection
Why not check your connection's working by going to the ee.co.uk website?
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
