Siemens router - set up guide
Need help setting up your Siemens router? This guide shows you how.
  1. Plug the broadband cable into the DSL socket on the back of the router
    The broadband cable is a grey cable with grey plugs.
    Broadband cable connected to grey socket on Siemens router
  2. Plug the other end of the broadband cable into the broadband filter
    Broadband cable ready to connect to broadband filter
  3. You'll also need to plug each piece of telephone equipment connected to your line into a broadband filter. This includes sockets for:
    - Telephones
    - TV services e.g. Sky
    - Answer phones
    - Faxes
    - Alarm systems - you might need to talk to an alarm engineer about this
  4. Plug the broadband filter into your phone socket
    Broadband filter connected to phone line
  5. Plug the power cable into the router
    Power cable ready to connect to Siemens router
  6. Plug the other end of this cable into a mains socket near the router
    Power socket - turned on
  7. Switch the rouiter on - press the power switch on the back
    Power switch
It'll take a couple of minutes for your router to start up. Just sit back and relax.
Connect computer to the router
Ideally, connect your computer to your router using a wired connection. You can always set up a wireless connection later.
  1. Plug one end of the network cable into your computer's network socket
    Ethernet cable ready to connect to computer
  2. Plug the other end into the yellow socket on your router
    Ethernet cable ready to connect to router
Update username and password
  1. Go to 192.168.1.1
  2. Enter the password admin and click OK
    Siemens Wireless Router welcome page - please enter your password
  3. The admin pages will load
    Siemens Wireless Router welcome page - admin pages
  4. Select Internet
  5. Enter your broadband username – letters should be entered in lower case, and remember to add @fs at the end
  6. Enter your broadband password – remember password is not the same as Password or PaSsWoRd
  7. Click OK
    Siemens Wireless Router welcome page - Internet option in menu selected
  8. The router will update your settings
    Apply settings page.
  9. Your router will connect to the internet
Check your connection
Why not check your connection's working by going to the ee.co.uk website?
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
