Siemens router - connect using WiFi
Want to connect a computer or device to your Siemens router? All the information you need is in this guide.
Wireless settings
To connect a computer or device to your router, you'll need:
  • Your Product Name (also called a wireless network name or SSID) e.g. OrangeE867FC
  • Your Security Code (also called a security key, wireless password, network key, or wireless network key)
You'll find these on the bottom of your router:-
Siemens wireless router - stick with wireless settings
Connect your devices
To connect, simply:
  1. Open the wireless software on your computer or device
  2. Select your router's wireless network name
  3. Enter your Security Code and connect
For more instructions, see one of our guides below:
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
