Technicolor TG589 router - Using the buttons
Power button
The power button allows you turn your TG589 router on or off.
Wireless button
The wireless button allows you to manually disable the wireless interface of your router. You can do this when nobody is using the wireless network.
To turn the wireless interface on or off, briefly press the wireless button.
To know whether the access point is enabled or not, check the wireless LEDs.
WPS button
The WPS button allows you to add new wireless clients to your network securely without the need to enter any of your wireless settings manually.
Reset pinhole button
The reset pinhole button allows you to reset your Technicolor TG589 router to factory defaults.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
