Powering on your Technicolor TG589 router
Only use the power supply unit that is supplied with your Technicolor TG589 router. If your current power supply unit is broken, contact your service provider or retailer.
  1. Plug the connector of the power supply unit into your Technicolor TG589 router power inlet port .
  2.  Plug the power supply unit into a nearby power outlet.
  3.  Press the power button to turn on your Technicolor TG589 router.
  4. The LED turns on. Wait at least two minutes to allow your Technicolor TG589 router to complete the start up phase.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
