Technicolor TG589 router - Fixing problems with the lights
None of the LEDs light up (Technicolor TG589 router does not work)
Make sure that:
  • the Technicolor TG589 router is plugged into a power socket outlet
  • you’re using the correct power supply for your Technicolor TG589 router device
    The power requirements for your Technicolor TG589 router are clearly indicated on the identification label of the Technicolor TG589 router. Only use the power supply unit that is supplied with your Technicolor TG589 router
  • the Technicolor TG589 router is turned on via the push button or rocker switch on the back panel
The Broadband LED does not light up or is blinking
Make sure that:
  • the DSL cable is correctly connected
  • the DSL service is enabled on your telephone line. For more information, contact your Internet Service Provider
  • check the Broadband settings on the web interface. Proceed as follows:
    a)    Browse to the Technicolor TG589 router web interface.
    b)    In the Broadband card header, make sure that the switch is in the position.
    c)    Select Broadband and then show advanced. If you're using the Technicolour TG589 router as:
       DSL gateway, make sure that ADSL2+ or VDSL is selected. Make sure to select the correct DSL type.
       Local router, make sure that Ethernet is selected.
    d)    Choose Switch connection mode.
    e)    After a few minutes the Status should switch to connected. If needed, click refresh data first.
Ethernet LED does not light up
Make sure that:
  • the Ethernet cable is correctly connected to the Ethernet port on your Technicolor TG589 router and your computer
  • you’re using the correct cable type for your Ethernet equipment, which is at least UTP CAT5 with RJ-45 connectors
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
