Techicolor TG589 router - Accessing the web interface
  1. Browse to http://192.168.1.1 on a computer or device that is currently connected to your Techicolor TG589 router (either wired or wirelessly).
    192.168.1.1 is the default IP address of your Techicolor TG589 router. If you have changed the IP address of your Techicolor TG589 router, use this IP address instead.
  2. The Techicolor TG589 router web interface appears. By default, you are logged in as guest. This means that some items may be hidden. To view all items, click Sign In and enter your user name  and password.If you did not change the default credentials, the user name is admin and the password is the ACCESS KEY that is printed on the product label of your Techicolor TG589 router.
  3. All cards are now available.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
