Technicolor TG589 router - Configuring WPA-Enterprise encryption
Please note, a RADIUS server must be readily set up on your local network to set up WPA-Enterprise encryption.
Follow these steps:
  1. Browse to the Technicolor TG589 router web interface.
  2. Choose Wireless. The Wireless page appears.
  3. On the left menu, select the access point that you want to configure.
  4. In the Security Mode list under Access Point, select one of the following modes:
    - WPA2
    - WPA+WPA2
  5. The following RADIUS settings are now available for configuration:
    - RADIUS Authentication Server's IP: enter the IP address of your RADIUS server.
    - RADIUS Authentication Server's port: enter the WPA RADIUS Port.
    - RADIUS Authentication Server's secret: enter the WPA RADIUS Key.
  6. Select Save to apply your changes.
  7. Reconnect your wireless client(s) to your Technicolor TG589 router.
Was this article helpful?
Thank you.
Thank you.
Thank you.
Thank you.
Getting the most from EE
Services and offers we have for you
