To get the Go Faster add-on:
How do I get the 4G Go Faster add-on?
In this article
We’ll then text you back with a few short steps to follow.
What is the Go Faster add-on?
This add-on gives you access to our fastest 4G speeds in the UK. Access to these speeds depends on the location you’re in and the device you’re using.
How much does the Go Faster add-on cost?
The Go Faster add-on costs £2 per month.
Will this add-on boost my speed abroad?
No. This speed boost will only give you access to our fastest 4G speeds in the UK.
Is there a minimum term that I need to commit to with this add-on?
No. You can remove this add-on from your account at any time:
What happens if I upgrade or move plan while I have this add-on?
This add-on will drop off your account and you’ll need to re-add it:
I’m on a Max plan. Can I get this Go Faster add-on?
No as you already have this benefit built into your plan as well as access to the BT Sport app and access to five additional 'roam like home' countries: the USA, Canada, Mexico, Australia and New Zealand.
How useful was this page?
Thanks for your feedback
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Book an appointment
Book an appointment
You can book a phone appointment with one of our local experts.
Something went wrong. Please try again later
We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
