Qualifying for Data Boost
If you have an EE pay monthly plan or a 12-month SIM only plan, you’ll qualify for a data boost when you sign up for EE broadband or 4G Home broadband.
And you'll keep the data boost as long as you're either an EE broadband or 4G Home Broadband customer and have an eligible EE mobile plan or SIM plan.
Choosing which number on an account gets the Data Boost
Only the broadband account holder can get the boost. So you need to make sure you give us your number when you sign up.
When will I get my Data Boost?
It can take up to 30 days after your home broadband or 4G Home account goes live for your data boost to kick in. We'll send you a text to let you know when it's done.
Can I share the Data Boost if I’m on a sharer plan?
Yes, as long as the data boost is added to the account holder's plan.
If I’m already a broadband customer, can I get the Data Boost?
Yes, you'll get the boost automatically when you sign up for one of our new broadband or 4G Home broadband packages. Or alternatively, if you weren’t on a pay monthly phone plan or 12-month SIM only plan and upgrade your mobile contract to one of these, we’ll also add the data boost onto your account.
We’re also giving the boost to some of our existing home broadband customers with an eligible mobile account so keep an eye out for a text from EE.
Why have I been sent a text saying my boost has been removed?
If you change either your mobile or broadband plan we may remove or change the data boost you receive. For example, if you've changed your broadband plan, your current mobile data boost will need to be removed before we can add your new one.
If you cancel your EE broadband or 4G Home Broadband contract we’ll remove the data boost from your mobile plan once your broadband plan has ended.
Switching a boost to another number
Sorry, but you can’t switch boosts to another number. So it's important that you give us the right phone number and it’s kept up to date.
The data boost will be applied to the same phone number we use to contact you with important information about your home broadband account. However you will be able to gift the data from your data boost to other numbers in your account.
